Hi everyone,
Even though i have installed gdal-1.1.9 on my linux
system.
On running the ./configure command for installing
grass-6.0.0 i get the following error
checking for GDALOpen... no
configure: error: *** Unable to locate GDAL library.
These r the files tht are present in the below
mentioned directories
/usr/lib/libgdal.1.1.so
/usr/local/lib/libgdal.so.1.4.1
/usr/local/lib/libgdal.la
/usr/local/lib/libgdal.a
/usr/local/lib/libgdal.1.1.so
Please help.
Rochelle
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
system.
that is a very old version now, consider upgrading.
make sure that /usr/local/lib is listed in your /etc/ld.so.conf file and
(as root) run /sbin/ldconfig.
Hello Hamish
As u said i added /usr/local/lib to the
/etc/ld.so.conf as root and ran ldonfig.Do i need to
relogin into my system for the changes to come to
effect?
I tried installing grass-6.0.0 but it gives me the
same errors as before.
Also as u suggested i tried installing latest version
of gdal.
when i run the "make" command for installing
gdal-1.3.1
i get following errors errors
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/home/r0chelle/gdal-1.3.1'
make: *** [check-lib] Error 2
r these packages not debugged already?
Please help me
Rochelle
linux
> system.
library.
I have added this suggestion to the Wiki FAQ page:
to
> effect?
No, as soon as ldonfig is done it should be ok.
try:
$ locate gdal-config
$ locate libgdal
where are they?
library.
look at the end of config.log for the error.
version
> of gdal.
> gdal-1.3.1
We need to see a dozen or so lines prior to that as
well. That just
tells us where it stopped, not why.
Hamish
Do You Yahoo!?
Hello Hamish
These are some of the few lines preceeding the error
messages. hope this will help u diagnos the
problem.Please look in.
/usr/lib/libnetcdf.a(attr.o)(.text+0x3f0): In function
`NC_findattr':
: multiple definition of `NC_findattr'
/usr/lib/libmfhdf.a(attr.o)(.text+0x1e0): first
defined here
/usr/bin/ld: Warning: size of symbol `NC_findattr'
changed from 124 in /usr/lib/libmfhdf.a(attr.o) to 140
/usr/lib/libnetcdf.a(nc.o)(.text+0x60): In function
`NC_check_id':
: multiple definition of `NC_check_id'
/usr/lib/libmfhdf.a(file.o)(.text+0x0): first defined
here
/usr/bin/ld: Warning: size of symbol `NC_check_id'
changed from 67 in /usr/lib/libmfhdf.a(file.o) to 61
/usr/lib/libnetcdf.a(var.o)(.text+0x5b0): In function
`NC_var_shape':
: multiple definition of `NC_var_shape'
/usr/lib/libmfhdf.a(var.o)(.text+0x1d0): first defined
here
/usr/bin/ld: Warning: size of symbol `NC_var_shape'
changed from 520 in /usr/lib/libmfhdf.a(var.o) to 373
make[1]: Leaving directory `/home/bnagesh/gdal-1.3.1'
R0chelle
to
> effect?
try:
$ locate libgdal
where are they?
library.
version
> of gdal.
> gdal-1.3.1
well. That just
Hamish
Do You Yahoo!?
Some time a go when I was workin on GRASS/GDAL ebuilds for Gentoo, I
recall similar problem. There is conflict between NetCDF and HDF4.
IIRC best soltion was to use only one of them.
Compilation worked fine, if HDF4 was compiled with szip flag, but
there was note, that GDAL may fail on HDF4 data loading. I had no
HDF4/NetCDF data to test it, so I cant say anything about faling
during runtime.
See more: http://bugs.gentoo.org/show_bug.cgi?id=89030
Maris.
Details from Gentoo bugzilla:
HDF4 and NetCDF _CANNOT_ be compiled into the same package. HDF4 contains some
of the code from NetCDF 2.x, and thus there are symbol conflicts. I mentioned
this in bug #39942, but I guess it was missed. This same problem also currently
affects the GDAL 1.2.5 ebuild.
I just wish I understood why. Can you
explain why compiling HDF4 with szip support fixes the conflicts?
I just found Bug#96187 and it says - "Also this is not easy to catch
because it compiles fine and only causes problems at runtime when the wrong
function gets linked / called."
2006/1/25, Rochelle MIranda <r0chelle_miranda@yahoo.com>:
Hello Hamish
`NC_findattr':
defined here
`NC_check_id':
here
`NC_var_shape':
here
R0chelle
> to
> > effect?
> try:
> $ locate libgdal
> where are they?
> library.
> version
> > of gdal.
> > gdal-1.3.1
> well. That just
> Hamish
Do You Yahoo!?
/usr/lib/libnetcdf.a(attr.o)(.text+0x3f0): In function `NC_findattr':
/usr/lib/libmfhdf.a(attr.o)(.text+0x1e0): first defined here
Versions of the HDF library which include built-in NetCDF support will
conflict with a separate NetCDF library. You will need to disable
either NetCDF or HDF support.
error
defined here
NetCDF support will
need to disable
Do You Yahoo!?
Hello Maris
Thanks a Lot for writing back to my query. As u
suggested there was a conflict betn the hdf4 and the
seperate netcdf installed on my system.
I went through the URL u gave.
On configuring gdal-1.3.1 without the hdf4 support
everything seems to be working fine
NetCDF and HDF4.
szip flag, but
loading. I had no
about faling
during runtime.
Maris.
the conflicts?
not easy to catch
> Hello Hamish
error
function
> `NC_findattr':
> defined here
140
function
> `NC_check_id':
defined
> here
61
function
> `NC_var_shape':
defined
> here
`NC_var_shape'
373
> R0chelle
need
> > to
to
> > > effect?
> > try:
> > $ locate libgdal
> > where are they?
the
installing
> > library.
> > version
> > > of gdal.
> > > gdal-1.3.1
as
> > well. That just
> > Hamish
> Do You Yahoo!?
protection around
Do You Yahoo!?
