[GRASSLIST:998] nviz error in grass61
Hello all,
I have a Grass61 cvs just compiled on a Sarge-2.6.8-686.
When I run a nviz session, the monitor is empty and the terminal says:
Xlib: extension "XFree86-DRI" missing on display ":0.0".
However I can load previous nviz sessions made with grass60.
Am I missing some lib? I tried to correct the DRI section in /etc/X11/XF86config as Markus once suggested, but that did not help.
Thanks!
a
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.1.392 / Virus Database: 268.5.3/331 - Release Date: 03/05/06
Try "export LIBGL_ALWAYS_INDIRECT=1".
The OpenGL library is trying to use direct rendering but the X server
doesn't support it. It /should/ fall back to indirect rendering; I
don't know why it doesn't.
