Hardware information needed
I'm buying a PC to work with GRASS for Linux. These are the main PC features:
PC Pentium Pro200
RAM 64 MB EDO
HDD 2,1 GB
What kind of video board is needed? Are there Linux incompatibilities with
SVGA Matrox Mystique (4 MB)?
And with the SCSI II controller?
Which version of Linux is suitable to work with GRASS?
Any suggestion is welcome! Thank you in advance.
Cristina Milesi
CETA - Centre for Theoretical and Applied Ecology *
GIS & Remote Sensing Lab. *
AREA Science Park *
Padriciano,99 - 34012 Trieste / Italy *
Tel. +39-40-9380098 *
Fax +39-40-226698 *
E-mail: milesi@sci.area.trieste.it *
On Tue, 28 Jan 1997, Cristina Milesi wrote:
PC Pentium Pro200
RAM 64 MB EDO
HDD 2,1 GB
Cristina,
    I'm a little reluctant to reply as I haven't ran GRASS much
lately. (I hope to change this in the future.) Also, my own well
tested and perfected Linux systems use extremely dated hardware.
    However, ... A Pentium Pro/200 with 32 mb RAM and an 2.1 gb disk
should work great. (Please send me one.) I'm not sure about the SVGA
Matrox card, but I expect it would work. Check the Hardware
compatiability list. The disk, CD, etc can be either enhanced ide or
SCSI. I personally much prefer SCSI. I generally use Adaptec 1542 (ISA)
or Adaptec 1740 (EISA) SCSI controllers. I like them and would recommend
either using an Adaptec or Bus Logic controller. Of course, you should
get a model for your bus (probably PCI).
    There are a number of distributions of Linux, including Slackware,
Red Hat, and Debian. All three of these are excellent general purpose
distributions, and thus are suitable distributions for GRASS. I use
Slackware, because I started with it; but would probably recommend Debian
to a new Linux user. (Ok, Red Hat is good too; and super good is you
happen to have a Dec Alpha workstation.) The distributions have version
numbers, but the distribution version number isn't as important as
the version of the LINUX kernel within the distribution. Many old kernels
work just fine. (I'm writing this note on a system running a version
1.0.8 kernel.) But, you definitely want ELF binary support which is
complete with kernel 1.2.13 and newer; and in practice I would recommend
installing a 2.0+ kernel. Most of my systems are running 2.0.?? from
the SLACKWARE distribution on vol1 of the Sept 96 release of InfoMagic's 6
CD developers set which retails for about $US25.00. It is complete and
stable and generally real nice; and will run either A. Holt's a.out
release of GRASS or Kang's ELF release.
                                          Dave Mandel
David Mandel, Linux Activist dmandel@transport.com
Internet Provided by: Transport Logic (503) 243-1940
               Serving the Pacific Northwestern USA
Portland * Vancouver * McMinnville * Salem * Bend
