Dear friend,
I just installed GRASS4.1 under a personal directory in a large platform.
Anything looks fine (so far) except that I can not generate maps in the
mapset by using the command "r.mapcalc".
For example, I have a map called "DEM "in Mapset "aggregate".
Everytime I use "r.mapcalc" to calulate new maps. I always get the message
as follow:
_________________________________________________________________________
Mapset <aggregate> in Location <tmp>
GRASS 4.1 > r.mapcalc test='DEM'
EXECUTING test = ... 100%
CREATING SUPPORT FILES FOR test
WARNING: closecell: can't move /usr/user0/wlk/tmp/aggregate/.tmp/tc/21306.2
to cell file test in mapset aggregate
minimum value 1040, maximum value 1900
GRASS 4.1 >
Of course, I did not get a "test" map in the mapset.
Can anyone please tell me where the problem is? Thank you very much!
wenling
Wen-Ling Kuo (wk14@cornell.edu)
Research Assistant, ABEN,
Cornell University
Ithaca, NY 14853
