Hi!
I remember that somebody mentioned
a program to import hdf files to grass (r.in.hdf?),
but cannot find it. Does anybody have any news on this
topic?
Thanks
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/alobo
Agustin,
The module is r.in.hdf and is present in your 4.2 version.
It's command-line and we use it to import NWS NEXRAD
data into GRASS. While it's not present in 5.0beta, it
*should* compile there. It will generate 4.x format files.
We're working on fp conversions for all 4.x modules, but
this is a slow process due to our current work loads. LEt
me know if you need any help with this.
Bruce
Bruce Byars
GRASS Dev. Team
Baylor University
Agustin Lobo wrote:
Hi!
topic?
Thanks
Agus
Dr. Agustin Lobo
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
Agus:
I do have the program that come with a previous distribution of GRASS
somewhere - I can dig it out and send it to you.
HDF is a very important file format. In fact, as all the EOS data
accessible trough EOS Data Gateway would be available as HDF-EOS I wonder
how much interest would be to build a more complete HDF-EOS support into
GRASS. I would be happy to contribute.
Ion Mateescu
Lamont Doherty Earth Observatory
Columbia University
Rt. 9w
Palisades, NY 10964
Tel: 914 365 8675
On Mon, 27 Sep 1999, Agustin Lobo wrote:
Hi!
topic?
Thanks
Agus
Dr. Agustin Lobo
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
Hi Bruce,
Do you know if r.in.hdf will read HDF MAS-50 files? This file
format is used on an hyperspectral sensor called MASTER with
50 bands.
Regards
Alejandro Hinojosa
At 12:44 PM 9/27/99 -0500, you wrote:
Agustin,
Bruce
Bruce Byars
GRASS Dev. Team
Baylor University
Agustin Lobo wrote:
Hi!
topic?
Thanks
Agus
Dr. Agustin Lobo
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
