header files
I have a small data set that I want to manipulate in GRASS. The problem
is the header file. Creation of this file requires that I specify the
number of rows, columns, and bytes per cell. As you know the product of
these 3 values must equal the file size. My file is 125124 mb. I have
400 columns and 107 rows. Dividing the file's size by the product of
columns and rows indicates I have 2.9 bytes per cell. This isn't
acceptable of course. I believe my problem lies in the presentation of
the data. I used a spreadsheet (Microsoft's Excel) to enter the data and
saved it as a text file. This program is limited to 256 columns so I
wrapped the columns down to the next line, starting a new line at each
new row. Is this my problem? If so does anyone have a suggestion as to
how I might create a text file without this problem? Your help is
appreciated.
Brad Robbins Dept. of Biology
brobbins@chuma.cas.usf.edu Univ. of South Florida
Assuming that you are generating your text file on a DOS machine, have you
tried running your file through the dos2unix filter on your Unix box? You
probably have DOS carriage returns (^M) that need to be deleted, which dos2unix
does. r.in.ascii does not care if all of your columns are located on one row
of text; it simply looks at you header and reads the data by 400 words per
row, assuming that you specified 400 columns.
Good luck!
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
