header in r.in.ascii
I think this is a problem that crops up in a few GRASS places:
if you use decimal degress, then use a "-" sign to indicate W or S.
if you use dd:mm:ss, then the E|W N|S flags are the way to go.
___________________________________________________
      __ L Dr Simon Cox
   ,~' L_|\ VIEPS Department of Earth Sciences,
,-' \ Monash University, Clayton Vic 3168
( \ Australia
\ ___ / Phone +61 3 565 5762
L,~' "\_x/ Fax +61 3 565 5062
           u simon@artemis.earth.monash.edu.au
