HELP!! Clark66->WGS84 ???#%@*!
Date sent: 25-AUG-1992 21:39:15
Thanks Fred:
But this brings up the question what spheriod are the UTM data referenced
too?? or isn't it referenced to a spheroid at all ?! (I'll look into it).
If I understand your question it is quite easy to get the results you want
the site data from the clark66 data set should be routed through m.ll2u
with the spheroid set to clark66 while the WGS84 stuff would be routed through
with the spheroid set to wgs84. Both will come out in the correct UTM zone
with the differences in the spheroids corrected.
Thanks again,
Gerry Hatcher
Ocean Mapping Development Center| gerry@omdc.gso.uri.edu {Internet}
University of Rhode Island | cbeam::gerry {span}
voice (401)-792-6940 | fax (401)-792-6849
