Dear Sri,
Can I have the ftp site address where you put the 'r.fill.dir', or have you put
it on the moon incoming directory.
Thanks in advance for your cooperation.
Kamarul
I developed this 'r.fill.dir', which needs a fortran and C compiler to
compile.I can put the src code on our ftp site or in moon incoming directory.
I have not worked with it for some time, there are some limitations about
how may rows and columns you can process at one time.Hope this helps.
Srinivasan
Texas A & M Univ.
srin@brcsun2.tamu.edu
