help - old Houston Instruments digitizer
I have inherited a digitizing tablet called a "HIPAD DIGITIZER", model
DT-11, made by Houston Instument, circa 1982 I suspect. It was used
with a PDP-11 based Image Analysis system put together by Dipix
Systems Limited.
My question is:
Does anyone have any technical information on this beast? What are
the odds it uses "RS-232" communications protocol? (It seems to use
three lines, of a standard 25-pin connector; lines 2, 7, and 25. The
2 and 7 sound promising, but 25 is wierd.) Any tips?
Tim.
Tim Martin *
Spatial Information Systems * Peculiar travel suggestions
University of Alberta * are dance lessons from God.
Tim.Martin@UAlberta.CA * -Bokonon
(403) 492-6586 *
