Stephen Dzurenko writes:
I am new not only to GRASS, but to UNIX. I guess I am really in for trouble.
Anyway, I am having trouble with step 1... getting the users manual to print.As README says, I type
sh utilities/printed-manualAnd I get
Processing sections 1 and 2.
Processing section 3.
Processing section 5.
Starting troff processes.
sh: sh: troff: not found
soelim: not found
Seems like you don't have troff and soelim in your path. Check the
printed-manual shell to see where it wants the program to be. In my
version it says:
PATH=/usr/ucb:/bin:/usr/bin ; export PATH
PRINTER=${PRINTER}-oscar ; export PRINTER
on my system soelim is in /usr/ucb and troff is in /usr/bin (I think
this is where they should be normally). You can try to find them on your
own system with the command
find /usr -name 'soelim' -print
find /usr -name 'troff' -print
Hope this helps!
Philip Verhagen
S t i c h t i n g R A A P
Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
1018 TV Amsterdam
THE NETHERLANDS
phone/fax: (31) 20 525 5834
e-mail: motte@hacktic.nl
