HELP: Probl. with v.in.dxf / v.support!!!!
Giorgos,
This is an old problem that never got fixed:
There was a bug in the file src/mapdev/Vlib/level_two.c that existed
for a short time between update 4 and update 5. Although it was
fixed and made it into the update_package 5, at the time the
s5.cpio* files were created, the bug was still there. So a diff
on the file included in the update_package vs. the file in the s5*
source results in:
176,177d175
< fclose(map->dig_fp);
< map->dig_fp=NULL;
If they downloaded the s5* source, the bug is still there, but if
they applied the update_package, they should be OK. I assume the
binaries should be OK since they were probably done after the
source & update package, but haven't tried them.
The fix:
download the file ftp://moon.cecer.army.mil/grass/incoming/level_two.c
and replace your src/mapdev/Vlib/level_two.c
Then recompile Vlib and v.build
- Bill
brown@gis.uiuc.edu
