I assume that you are running XGRASS. You can overcome at least part of the
problem by starting a GRASS shell and using the g.manual or g.help commands
from there instead.
As a fresh Grass user I consider the information in the
help on Grass topics area and the on line user's manual
as useful. But one problem with these functions is that
the output is given in windows where the window width is
smaller than the width of the lines in the explanations
that are given. This pakes the process of reading a bit
hard, because i have to scroll the the messages horisontally
for each line I read. So now I wonder if anyone knows how
to change the window width, or how the make letters in the
dialog window smaller to solve this problem.Thanks
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
