From grass-lists-owner@max.cecer.army.mil Fri May 14 13:18:49 1993
Date: Fri, 14 May 93 15:12:54 MDT
Posted-Date: Fri, 14 May 93 15:12:54 MDT
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassp-list@max.cecer.army.mil
Precedence: Bulk
To: grassp-list@amber.cecer.army.mil
Subject: help with compile error
Content-Length: 2353
X-Lines: 71Hi,
I'm getting the following error trying to compile xgrass:
gcc -s -o /scratch/grass.4.1/bin/xdigit OBJ/ask_cat.o OBJ/clip.o OBJ/coor_pop.o OBJ/custommenu.o OBJ/debugmenu.o OBJ/debugf.o OBJ/digitmenu.o OBJ/digitize.o OBJ
.. stuff deleted
bes/LIB/libdig_atts.a /scratch/grass.4.1/src/libes/LIB/libproj.a /scratch/grass.4.1/src/libes/LIB/libgis.a -lXm -lXt -lX11 -lm
ld: -lXm: No such file or directory
collect: /usr/bin/ld returned 4 exit status
make: *** [/scratch/grass.4.1/bin/xdigit] Error 1
GISGEN failure at STEP: src/xgrass/xdigit
Happened to me, too. The problem is in the Gmakefile for src/xgrass/xdigit.
It is failing to include the Motif library path in the compiler arguments.
OGI should attend to this problem in GISGEN. Meanwhile, add the
$(XMLIBPATH)
argument to the Gmakefile in src/xgrass/xdigit as noted in my "diary" entry
below. If it doesn't work, then it may be time to annoy the sys admin
as Darrell suggested.
seems like I need to add $XMLIBPATH to compiler arguments so . . .
manually edited xdigit Gmakefile to
$(PGM): $(OBJS) $(GPROJLIB) $(VECTLIB) $(GISLIB)
$(CC) $(LDFLAGS) $(XMLIBPATH) -o $@ $(OBJS) $(LINKMLIB) $(VECTLIB) $(XGILIB) $(LIBTRANS) $(DIG_ATTLIB) $(GPROJLIB) $(GISLIB) $(XEXTRALIBS) $(XMLIB) $(XTLIB) $(XLIB) $(MATHLIB)
greg
Greg Koerper Internet: greg@heart.cor.epa.gov
ManTech Environmental Technology, Inc. UUCP: hplabs!hp-pcd!orstcs!koerper
US EPA Environmental Research Lab
200 SW 35th St., JSB
Corvallis, OR 97333 "The 90s will make the 60s look like the 50s.
(503) 754-4490 Just ask your kids."
fax: (503) 754-4338
