Help with v.import
Sharyl Walker wrote
  I want to take an ascii file of x,y coordinates
(in UTMs) which define the boundary of an area and create
a GRASS4.1 map. The original ascii file has no headers --
just the x,y coordinates (x and y separated by spaces, 1 coordinate
pair per line).
  What I've tried so far is the following:
    1) Edit the original ascii file to look like
       an ascii arc file according to the example
       in the Programmer's Manual. That is, I
       added header information, put in arc type
       and no. of coordinate pairs, and switched
       the values to y,x format. I stored this
       modified file under the dig_ascii subdirectory
       of my mapset.
    2) Next, I ran v.import using option 3 to
       convert an ascii vector file to GRASS vector
       format. This seems to run OK, but when I
       try to display the map, I get nothing.
  Am I missing some important steps? Is there an easier
way to convert a straight ascii file to something GRASS can use?
  Thanks for any advice.
Sharyl Walker
Dept. of Agricultural Engineering
University of Illinois
guernsey@holstein.age.uiuc.edu
We had the same kind of troubles here and the problem seems to be that you have to switch your coordinates. Or just to find out if that is working first change your region by switching the northing and the easting
* Ronnie Lassche *
* Department of earth sciences *
* Free University *
* Amsterdam *
* lasm@geo.vu.nl *
