I had a similar experiance when I downloaded the binaries. I never did figure
out why it happened and several from this list offered suggestion of which
none worked. For other reasons I downloaded the source and did a complete
rebuild including XGRASS. The problem went away. This suggestes that the
keysym table is compiled into the code. I was not under the impression that
this was the case, I thought the it was dynamically loaded at runtime. I
never persued it further since my purposes were satisfied.
Doug Dotson
dotson@tate.com
