I am writing a script in Unix C-shell for the GRASS-CAMPS interface and
it looks like the following:
setenv GRASS /usr/local/bin
setenv CAMPS /home/camps.data
setenv GISRC $home/.grassrc
setenv GISBASE /home/grass/sun4
setenv XDRIVER_HEIGHT 506
setenv XDRIVER_WIDTH 710
setenv XDRIVER_LEFT 291
setenv XDRIVER_TOP 213
The last 4 lines are not working. I want the field map to appear on a
particular location but it always appear at the top left corner. Am I
making a mistake anywhere?
If you don't have an answer, can you pl suggest some one else (with their
email or ph no) to seek help?
Thanks a lot.
Thanks.
--Nachi
* Nachiappan Narayanan *
* Virginia Tech *
* nachi@vt.edu *
* WORK (703)-231-9116 *
* HOME (703)-552-7332 *
