here is v.plant
Sorry folks - I seem to be having some difficulty accessing moon (at least
I cannot read anything in "incoming" so here is v.plant.
----------------------- cut here ---------------------------------------------
#!/bin/sh
# fills in intermediate points on vectors
# if the point spacing is greater than a threshold
# it uses the dig_ascii format as an intermediate step and replaces the original file
# sjdc 10/2/95 s.cox@dem.csiro.au
if [ ! "$GISRC" ]
then
  echo "Sorry - you are not running GRASS">&2
  exit 1
fi
echo ""
echo "v.plant fills in intermediate points on arcs with a specified spacing"
echo "Take care: the original file is replaced with the new one"
echo ""
echo "Simon Cox, CSIRO, 10/2/95"
echo ""
eval `g.gisenv`
: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
g.ask type=old prompt="Select a vector (dig) map to process" element=dig desc=vector unixfile=/tmp/$$
. /tmp/$$
rm -f /tmp/$$
if [ ! "$name" ]
then
  exit 2
fi
if [ $mapset -ne $MAPSET ]
then
  echo "Sorry - you can only do this operation to maps in the current mapset"
  exit 3
fi
echo ""
echo "Enter a number for the minimum spacing of points on arcs (in map units)"
echo ""
gotit=0
while [ $gotit -eq 0 ]
do
      echo -n "spacing: "
      read space
      if [ $space -ge 0 ]
      then
              gotit=1
      else
              echo "Sorry, spacing must be non-zero"
      fi
done
# remove existing dead lines
v.clean $name
# write dig_ascii file
oname=${name}.old
v.out.ascii input=$name output=$oname
# cd to dig_ascii and process ascii file
cd ${GISDBASE}/${LOCATION_NAME}/${MAPSET}/dig_ascii
nawk -v thold=$space '
BEGIN{
i=0
if(NR<15){ print $0; next; } # pass header info through unchanged
if( $1 ~ /^A|a|L|l|S|s/ ){ # found new object header
  if(i){ # write out previous object
    print objecttype,i
    for(j=1; j<=i; j++) print " ",y[j],x[j]
  objecttype= $1; # initialise for new object
  i=0;
  if( objecttype ~ /^a|l|S|s/ ){ # dont interpolate for sites or dead objects
    print $0; # pass these through unchanged
    skip=1;
  else skip=0;
  next;
if( skip ){ print $0; next; } # pass data through unchanged & move to next line
i++; y[i]=$1; x[i]=$2; # read coords into x,y array
if( i<2 ) next; # if this was first coord move to next line
ydist= y[i]-y[i-1] # measure distance to last point
xdist= x[i]-x[i-1]
dist= sqrt( ydist*ydist + xdist*xdist )
if( dist > thold ){ # fill in intermediate values
  n_intervals= int( dist/thold )
  y_increment= ydist/(n_intervals+1)
  x_increment= xdist/(n_intervals+1)
  y[i+n_intervals]= y[i]
  x[i+n_intervals]= x[i]
  for( j=1; j<=n_intervals; ++j ){
    y[i]= y[i-1]+y_increment
    x[i]= x[i-1]+x_increment
    ++i
END{ # write out last object
if(i){
  print objecttype,i
}' $oname > $name
# only remove dig file - we want to preserve to atts and cats etc.
rm $file
# load processed file
v.in.ascii input=$name output=$name
v.support map=$name
#tidy up
rm $name ${name}.old
echo "Done"
