------------------------------ Start of body part 1
Anbei ein paar Tip's aus dem "Osten" fuer Kollegen Osten. MfG, Frank H.
------------------------------ Start of forwarded message 1
Sender: lists-owner@amber.cecer.army.mil
Message-ID: <"920611105706868-MTALRZUNI*/S=Harald.Osten(a)GEOPHYSIK.UNI-MUENCHEN.DBP.DE/PRMD=gmd/ADMD=dbp/C=de/"@MHS>
Reply-To: grassp-list@amber.cecer.army.mil
Precedence: Bulk
Subject: HEL
Date: Fri, 12 Jun 1992 06:39:57 +0000
X400-Trace: DE*DBP*UNI-MUENCHEN; arrival Thu, 11 Jun 92 10:57:34 +0200 action
Relayed
X400-Trace: DE*DBP*TU-MUENCHEN; arrival Thu, 11 Jun 92 10:57:45 +0200 action
Relayed previous DE*DBP*UNI-MUENCHEN
P1-Message-Id: DE*DBP*UNI-MUENCHEN; 920611105706868-MTALRZUNI
Ua-Content-Id: 920611105706868-
Precedence: Bulk
HEL
------------------------------ End of forwarded message 1
------------------------------ Start of forwarded message 2
From: Martin Ameskamp <ma@informatik.uni-kiel.dbp.de>
Message-ID: <RFC-822:9206110955.AA08416@informatik.uni-kiel.dbp.de>
Precedence: Bulk
Subject: Re: HEL
Precedence: Bulk
> Relayed
>Precedence: BulkHEL
irgendwer scheint da Adressen verwechselt zu haben ...
Martin
Martin Ameskamp, Kiel University, Germany
Fax: ++49 431 8804054, Voice: ++49 431 8804474,
email: ma@informatik.uni-kiel.dbp.de
------------------------------ End of forwarded message 2
------------------------------ Start of forwarded message 3
From: hoffmann@urzdfn.kartographie.tu-dresden.dbp.de
Message-ID: <920118081324*/S=hoffmann/OU=urzdfn/OU=kartographie/PRMD=TU-DRESDEN/ADMD=DBP/C=DE/@MHS>
Precedence: Bulk
To: grassu-request@amber.cecer.army.mil
Subject: tud>request
Date: Fri, 12 Jun 1992 06:39:58 +0000
help
who
dir
------------------------------ End of forwarded message 3
------------------------------ Start of forwarded message 4
Message-ID: <"<9201180718.AA14665@zorro.cecer.army&mil>*"@MHS>
Precedence: Bulk
To: list:;
Subject: help.txt: Part 1 of 1
Date: Fri, 12 Jun 1992 06:39:59 +0000
Apparently-To: <hoffmann@urzdfn.kartographie.tu-dresden.dbp.de>
This is the helpfile for the GRASS-list; if this file does not answer your
questions, or you require a human response, send electronic mail to
lists-owner@amber.cecer.army.mil .
For each command, you may either type the full command or just the first
three letters. The server does not care about case (except for filename
arguments to the GET command, which must match exactly). Valid server
commands are:
SUBscribe [name]
subscribes current path to mailing list.
optional [name] parameter specifies name to display in WHOs.
if [name] is "-", WHO does not display address.
UNSubscribe
unsubscribes the current path from the mailing list.
if the path cannot be found in the mailing list, listman
notifies the sender and the list-owner.
WHO [name]
returns a sorted list of list subscribers, minus all users who
subscribed with the - option.
DIRectory
returns the mailing list's archive directory. The log of
recent submissions is in a file called LOG. Other files may
be available from time to time.
GET file
returns the file from the list's archive directory.
the all parameter causes listman to return all the files.
The filename must match exactly (spelling, case, punctuation).
PINg
"pings" the mailing list, causing a simple "I'm alive"
response to be returned.
HELp
returns the list's help file from the archive directory.
For file accesses, the server will mail a confirmation note detailing what to
expect. If the file is reasonably short, it will simply send the file in a
mail message. If the file is long, it will "uuencode" it and send it in
mail-sized chunks (the explanatory note will tell how many to expect). Once
you receive the file, you must concatenate the pieces and uudecode it; ask for
the file "uuencode.help" for details on this process.
Sincerely,
The Office of GRASS Integration
US Army Corps of Engineers, Construction Engineering Research Lab
P.O. Box 9005
Champaign, IL 61826-9005
------------------------------ End of forwarded message 4
