When you use a map for color in SG3d, it uses the same
color table used by GRASS as when you do a d.rast. So
you can use r.colors or if you understand how the
color tables work, edit your color table file for
the raster (in $LOCATION/colr/<rastername>) to reverse
the color ramp.
