How do I get .shp files into Grass as a vector file. I will worry about
getting them out later. Thanks.
James Harper
Jharper@jps.net
James Harper
Jharper@jps.net
James,
You can try downloading my v.in.shape code from:
http://gdal.velocet.ca/projects/grass/index.html
Are you trying to import points, lines or polygons? Points and polygons are
still somewhat problematic. Points are not imported as sites (but as vector
points), and polygons are imported as closed arcs, but boundaries between
adjacent polygons will always appear double digitized. Also, there aren't any
internal points generated to label the polygons.
I would appreciate any reports of problems with this program.
Best regards,
I set the clouds in motion - turned up | Frank Warmerdam, Programmer for Rent
light and sound - activate the windows | http://members.home.com/warmerda
and watch the world go round - Rush | warmerda@home.com
Thanks for the help Frank. I will let you know how it works out.
James Harper
Jharper@jps.net
-----Original Message-----
From: grass@pandora.cecer.army.mil [mailto:grass@pandora.cecer.army.mil] On
Behalf Of Frank Warmerdam
Sent: Monday, March 29, 1999 5:08 AM
To: grass@cecer.army.mil
Subject: Re: How do I get ArcView shape files into Grass?
James,
any
Best regards,
Rent
