How do I get graphics in Linux?
Could someone explain to me how I set up my $GISBASE/dev/fifo links so
that "d.mon" doesn't complain as such:
Sorry, <$GISBASE/dev/fifo.1a> not available
Have GRASS adminstrator check etc/monitorcap file
Can't stat $GISBASE/dev/fifo.1a
I am running GRASS 4.1 on a Linux box running the 1.1.18 kernel. I
did not compile the GRASS software, but installed it using "cpio" with
the Linux cpio archives. I have X windows on this machine, but I get
the same error if I run GRASS in an 'xterm' window in X. (The
monitorcap file seems to think there is an X windows terminal
associated with 'x0' and I suspect this is one problem. Runnig)
Also, I believe the 'dev/fifo*' entries are really supposed to be
links, no? They are currently all zero length. I don't really
understand what a "named pipe" is so this could be a fundamental
problem. Do these need to linked to my /dev/tty?? system entries?
Don Maszle
