how do i read documents
i have unloaded the installGuide.ps.Z file onto my machine but i am
not sure which compression package puts a Z onto the end of the file,
anyone?
use 'uncompress'
also, we know that we can print out postscript files, but how do we edit
them?
As you may observe fromt the discussions on the list, this is a BIG problem.
In 99% of the cases, you may preview your file with some packages
(ghostview for instance), but editing is something you should usually do
before creating a ps file
          Andrea Giacomelli
          andreag@idra1.iar.polimi.it
          DIIAR Politecnico di Milano, Italia
> anyone?
> them?
Andrea,
There are several "zipping" packages available that will uncompress your
files. Try an "unzip" or "gunzip" command.
I found that you can edit postscript files using UNIX's vi editor. The
problem is reading the script. It will take awhile but after spending some
time you'll begin to make some sense out of the PS gibberish. At the
start of each page is a header listing the page numbers of the previous
and next page. Use these as guides to move around in the document.
Good luck,
Brad Robbins
brobbins@chuma.cas.usf.edu
