how do i read documents
Date: Fri, 5 Aug 1994 09:16:38 +0200 (MET DST)
Reply-to: Cosyn Bart <Bart.Cosyn@rug.ac.be>
Subject: Re: how do i read documents
Reply-to: grassu-list@max.cecer.army.mil
Sender: grass-lists-owner@moon.cecer.army.mil.
Reply-To: grassu-list@moon.cecer.army.mil.
Precedence: Bulk
To: Rica Saporta <saporta@smokey.forestry.utoronto.ca>
Cc: Grass users <grassu-list@max.cecer.army.mil>
On Thu, 4 Aug 1994, Rica Saporta wrote:
Dear,
also, we know that we can print out postscript files, but how do we
edit
them?
In addition to Giacomelli's mail I inform you you can find
text-processing and viewing software in the anonymous site:
ftp.sunet.se
in subdirectory /pub/text-processing/postscript
      Bart
     Ir. Bart Cosyn
     Laboratory of Hydrology & Watermanagement
     Fac. of Agricultural Sciences and Applied Biological Sciences
     University of Gent
     Coupure Links 653
     B-9000 Gent
     Belgium
     Tel +/32/9/264/61/37
     Fax +/32/9/264/62/36
     E_mail:Bart.Cosyn@rug.ac.be | or bcosyn@allserv.rug.ac.be
From: Andrea Giacomelli <andreag@idra1.iar.polimi.it>
Precedence: Bulk
To: grassu-list@max.cecer.army.mil
Date: Fri, 5 Aug 94 9:00:36 METDST
use 'uncompress'
edit
them?
As you may observe fromt the discussions on the list, this is a BIG
problem.
In 99% of the cases, you may preview your file with some packages
(ghostview for instance), but editing is something you should usually
do
before creating a ps file
          Andrea Giacomelli
          DIIAR Politecnico di
Milano, Italia
Date: Fri, 5 Aug 1994 07:53:32 -0400 (EDT)
From: "Brad Robbins (BIO)" <brobbins@chuma.cas.usf.edu>
Precedence: Bulk
Cc: grassu-list@max.cecer.army.mil
There are several "zipping" packages available that will uncompress
your
files. Try an "unzip" or "gunzip" command.
I found that you can edit postscript files using UNIX's vi editor. The
problem is reading the script. It will take awhile but after spending
some
time you'll begin to make some sense out of the PS gibberish. At the
start of each page is a header listing the page numbers of the
previous
and next page. Use these as guides to move around in the
document.
Good luck,
Brad Robbins
