Bjorn Svensson writes:
How can I get a hardcopy map showing a vectorfile WITH ITS ATTRIBUTES.
I have a vector file with attributes/categories and I'd like the categories
to print in different colors or at least with attributes as labels.
Although GRASS needs individual vector layers to be able to print in different
colors, the alpha command v.reclass in GRASS4.1 allows you to generate these
layers quite easily from a single layer with multiple attributes. Labeling,
however, is not quite so easy...
(lines deleted)
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
