How Print Vector Attribute on Map ? ? ?
Bjorn Svensson writes:
> How can I get a hardcopy map showing a vectorfile WITH ITS ATTRIBUTES.
> I have a vector file with attributes/categories and I'd like the categories
> to print in different colors or at least with attributes as labels.
You can use the command d.vect.cats in src.contrib (4.1), to draw
vectors in different colors according to the category label values
by running the command several times with differing cat and color
value combinations.
James A. Farley Technical Director, CAST/NCRI-SW
            12 Ozark Hall, Univ. of Arkansas
jim@cast.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
