> I think that the only way is using sexagesimal degrees
> with decimal fractions (I.e., 40deg 30min would be
> 40.5). At least this is what I remember from the last time
> that I had to do it (v.4.0).> > "Enter coordinates as east north": ??? ???
> > I have
> > 10E 43' 30"
> > 47N 34' 0"finally we got it:
Enter coordinates as east north: 10E 43 30 47N 34 0
So no recalculation is required luckily.
It works fine. It was the first time I needed lat/long...
Too bad, I was wrong! The table created by i.points is
not o.k.
So I will recalculate every position in decimal degree
i.points accepts only decimal degree.
Maybe this is interesting for others transforming into
lat/long locations.
