How to snap nodes
GRASS wrote:
I imported some DXF's as follows:
        v.in.dxf dxf=a.dxf lines=7111,7114
        v.in.dxf3d dxf=a.dxf lines=7111,7114
        v.support map=a.7111 option=build
        v.support map=a.7114 option=build
        v.patch input=a.7111,a.7114 output=a
        v.in.dxf dxf=b.dxf lines=7111,7114
        v.in.dxf3d dxf=b.dxf lines=7111,7114
        v.support map=b.7111 option=build
        v.support map=b.7114 option=build
        v.patch input=b.7111,b.7114 output=b
        v.patch input=a,b output=ab
        v.support map=ab option=build -s threshold=1
This failed to snap nodes.
        d.vect ab
draws two disconnected maps.
What's wrong?
Huidae Cho
Hi
Some thoughts:-
Is the snap distance enough? If it's not that, maybe try changing the
scale value in v.digit (to a small value like 200 or 50). At present
nodes will only snap to other nodes, not for example to lines. Perhaps
that is a thought for future development.
David
On Tue, Aug 22, 2000 at 12:13:47AM +0000, David D Gray wrote:
GRASS wrote:
> Hi all,
> d.vect ab
> What's wrong?
> Regards,
> Huidae Cho
Hi
Some thoughts:-
David
ANother comment:
Please check if a map scale has been set to the map. If not, the
snapping won't work (I already got that experience).
Use v.digit to set the map scale to a reasonable value.
If there is none, the v.in.dxf should be modified to set either
the correct scale (if it can be found in DXF file) or a
default map scale. A map scale of 1:1 will not work.
Maybe this helps?
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
