Hi Malcolm,
I do know that you can use the command "setcolor [category] [color]"
in your ps.map script to change the color of your categories.
Don
Hi Malcolm,
Don
You learn something new every day!! Have you used this successfully? What
is the acceptable domain of color names (standard GRASS colors?), and is
this command sensitive to placement in the scripts?
-Malcolm
On Thu, 6 Jul 1995
dgc@cast.uark.edu wrote:
Hi Malcolm,
in your ps.map script to change the color of your categories.Don
