Hi folks,
Sorry it took so long for me to respond, but I've been waiting for a message
from someone who helped me set up my HP650c. Here is her response:
Hi Bill, The grass people themselves told me they did not write a device
driver for your type of HP plotter, nor did we. This is actually quite a
lot of work which is why you'd be so popular if you published one! The
solution was to run ps.map and save the output to a file. From there you
just print the file to the plotter with the lpr command. The plotter
understands postscript, so things print. The problem you're having
(getting grass to specify different pen numbers) may relate to the
fact that there is no device driver. It doesn't surprise me that p.chart
does not work since the Grass people told me the only print command that will
work for you (since you have no device driver) is ps.map. Perhaps there is
a way you can get ps.map to do what you need? I don't think any of the
other p.* programs will work either. Sorry I can't be of more help. Leslie
Here is some other information that may help:
1) To get the HP650c to work, make a subdirectory called ps.devices under the
paint directory. Create a file in the paint subdirectory with the name of the
postscript painter and the following information:
level: 1 or 2 (it doesn't seem to matter)
page width: 36
page height: 54
top margin: 0.5 (or whatever)
bottom margin 0.5 (or whatever)
left margin: 0.25 (or whatever)
right margin: 0.25 (ditto)
resolution: 300
2) The setcolor command in ps.map does not seem to work. Also, I can't use
a user-defined colortable because I can't print out the 125 colors that
grass recognizes (that is the colortable command wants a value and I don't
know what colors the values relate to).
3) Although the HP650c reference manual tells you to set the language to
"automatic," this won't work. You have to set the language to Postscript
instead.
4) The add.pagesize isn't working correctly with the HP650c. The command
seems to work properly, but when I try to print the map out it disappears
into the plotter's black hole (that is it receives the information but never
prints anything out).
I hope this helps, but could someone answer my original question: How do
I control the raster color output since the setcolor command isn't working?
Bill Green
Archaeology Lab
SUNY-Albany
wg1938@cnsunix.albany.edu
