HPLaserJet 4M and MAPGEN
%%% Hi everyone,
%%% I have a HPLaserJet 4M laser printer and want to connect
%%% it to SCS GRASS-MAPGEN4.1 interface.
%%% Does anyone know what things I did wrong here? does MAPGEN4.1
%%% supports HPLaserJet 4M or not? What is the output format that program
%%% "plotter" used? Does it generates postcript as output?
%%% Thank you for any help in advance.
%%% PK Lin
%%% Tel: (617) 942-1655
%%% E-mail: pklin@cerf.net
%%%----- End Included Message -----
The GRASS MAPGEN Interface versions (3.1, 4.0, 4.11, and 4.12) all work with
the HPLaserJet laser printer in black/white postscript.
Step 1: build a plotter output file
There are two ways to build a postscript plotter file in mapgen.
You can use the mapgen plotter command directly or use the interface script
plot.sh.
Step 2: send the output file to the device via your lp spool
Instructions for building a plotter output file in postscript
The following is the correct syntax to use the plotter command:
plotter -d ps ovm/* | lp -d[printer]
where:
printer is the name of the print spooler setup on your sun for the HPLaserJet
I suggest that you try this command first. If you get satisfactory
results, then you will need to edit a support file in mapgen for the
plot.sh command.
Edit the file $GISBASE/mapgen/etc/PLOTTER
add the print spooler name for the HPLaserJet in the first field.
add the mapgen driver name "ps" in the second field.
add the correct port
Example of PLOTTER file:
PRINTER_NAME PLOTTER_NAME DEVICE
hpgl hpgl /dev/tty00
cps cps /dev/tty00
HpLaserjet ps /dev/tty00
Run the plot.sh command selecting HpLaserjet
That's about all there is to it.
If you have any more questions email me back directly.
Jill
