|I've been asked the following:
|The i.cluster program requires more than one band ("group")-
|If I wanted to try an unsupervised classification on a NDVI
|band alone, am I out of luck here? I suppose I could try
|using AVHRR band 1 or 2 and the NDVI - but I'm not sure if
|that would give proper results. Any comments?
|Anyone have a handle on this?When I wrote i.cluster, I made it require 2 or more bands. That could
easily be attributed to my novice status as an image processing/
statistical inference person at the time. There is probably no good
reason to require 2 or more bands except that the original code
I was working from would divide by 0 if there was only one band.
Anyone interested in seeing how the 2 band restriction can be lifted?Michael
Why not make a "dummy" file of all value = 1?
Jerry Thompson
