i.cluster
On Mon, 17 Aug 92 12:50:40 PDT Greg Gaston said:
I am working with i.cluster and i.maxlik on multi-temporal GVI data for the
former Soviet Union and I have some questions:
- Has anybody worked out a method of establishing the "natural" number of
clusters that occur in multi-image data? Or a description of how changing the
input parameters can change the results?
I have experimented with the input parameters that i.cluster asks for and I
have
some interesting results, however I would like to be able to justify my
results
with more than "it just looks better".
Well it is rather methodical question than clearly connected to
GRAss . Isn't it? I think so that number of cluster depends on the
image and also very inportant question is what is cluster ?? Also
question is what kind of methods are You using ? I dont know what
kind of algorythm is build in GRASS ?? According to my small experience
very logical seems to be AMNO algorythm which is seaching for modes
- AMNO (Analysis of Modes) when we assume multimodal normal data distri-
bution. Well maybe You can try it. If You need more fell free to
touch me directly.
indicate classes are closer than large numbers... but what are the units? When
I specify a class separation of .7, what units am I using and can I use this
matrix to compare the within class variation to the between class variation?
Thanks, Greg G.
well the cluster evaluation is also not so easy. You have mentioned
intercluster evaluation - there is also intracluster evaluation using
compactness coef. If You would like to use it - I can send You a referenc
of it.
Comming back to AMNO - the input parameter is not a number of clusters
but coef. ALFA.
    Anyway if You are interested in methodical problems of image
processing - there was created list IMAGRS-L at CSEARN.BITNET which is devo-
ted to image processing of remotelly sensed data. It is truth that it
not very active but maybe You can find it useful(there is aprx.200people)
  Sincerely
  I I I
  I----I I ----- it is A H O J in Slovak language
  I I I & Slovakia is a part of
                         Czecho-Slovakia in Central Europe
        Peter Sincak, Ph.D.
                 Kosice, Technical University of Kosice, E-Fac.
  Department of Cybernetic & Artificial Inteligence
  Czecho-Slovakia, E-mail - KUKO@CSPUNI12.BITNET
                                 KUKO@ACI.CVUT.CS
                       FAX - 0042 95 343 92
                       Voice - 0042 95 578 64
                  CITY AIR-plane connection = YES
