GRASS community-
It seems that my i.fft and i.ifft are not working on my Linux
machine. I am getting a "G_malloc out of memory" error when I try to run
them.
today I had a similar problem. I fixed it clearing my /tmp directory...
That should be all - your /tmp might be to small. Some temp.files
are also created in your grass_database. i.fft etc. are very
space consuming depending on the size of your raster image.
Hope this helps
neteler@geog.uni-hannover.de
PS: Try the new Linux GRASS 4.2.1 binaries if you like.
http://www.laum.uni-hannover.de/iln/grass/grass42/
Markus-
Thanks for the information. It seems that it was indeed some kind of
system limitation and not a problem with GRASS.
Thanks again.
Jeff Hollenbeck
Dept. of Fishery and Wildlife Science
New Mexico State University
jhollenb@nmsu.edu
On Tue, 20 Jan 1998, Markus Neteler wrote:
> GRASS community-
> them.
Hope this helps
