i.median colortables
Each raster map that is produced has a number of support files
automatically created. At one time a histogram file was created
automatically. with a count of each value that occured in the
rastermap. This process slowed the system down enough that it
wasn't worth keeping for the few instances that a histogram might
be needed. r.support can be used to generate this histogram
support file.
A simpler support file which just keeps track of the minimum and
maximum values in the raster map is always produced. This is
called the range file. Both the histogram file (if there is one)
and the range file (there should always be one) live in the
cell_misc directory. For example, if the raster map is called
"soils", the the range file is cell_misc/soils/range and the
histogram is cell_misc/soils/histogram.
If i.median is producing weird results and you think it is due to
the lack of the histogram (note it is a warning only), then
create histograms using r.support.
|I've been trying to use i.median to produce false infrared
|images from Landsat tapes, and am given error messages like
|"WARNING: Histogram for [file name in PERMANENT] missing"
|What produces these histograms? I've run g.support and r.stats
|but neither seems to save a histogram.
|A possibly related question: when I have run i.median (ignoring
|the no-histogram error) the same color is applied to a nu
ber of
|different data values, so that the resulting image has only a few
|different colors in largish clumps. Michael Shapiro wrote a few
|weeks ago that "The number of colors in the color tables for raster
|maps depends only on the the number of categories in the raster map."
|How does GRASS determine how many categories are in a composite
|map like that produced by i.median, and is it possible to set this
|number in some other way to produce a colortable with more different
|values? Would the lack of a histogram cause GRASS to produce a more
|limited colortable?
|Thanks for any advice on this question --
|Nick Cahill
|nick@ikaros.harvard.edu
Michael Shapiro U.S. Army CERL
email: shapiro@zorro.cecer.army.mil Environmental Division
phone: (217) 352-6511 ext 526 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
