dear friends:
I am using for digitizing maps the program AUTOCAD version 12 installed
in a PC (IBM Compatible). Now I need to use those maps in a GIS Grass4.1
installed in a Workstation SUN sparc Solaris.
the maps was saved with a DXF format in a diskette 1.44 HD (format for
windows pc ) and I don't know how I can use it in a workstation with and
operation system UNIX.please it will be useful to receive some answer to solve my problem
thanks
claudio szlafztein
geological departament
University of Para
Braziliosele@marajo.ufpa.br
Claudio
You can use the grass command v.in.dxf and import your file to
a location that has the same projection as your digitized map.
Hope it helps
Regards
Alejandro Hinojosa
http://www.cicese.mx/~alhinc/
Research Associate
Earth Sciences Division
CICESE
Ensenada, Baja California, Mexico.
