Hi (Y')all,
I have a few questions concerning some problems that I'm having using
GRASS. Hopefully some one out there might know of solutions to the
following:
1) When I try to use "i.pca" to transform 4 entire SPOT images (52 MBytes
each) the job gets killed by the system. Is this a normal response when
trying to carry out PCA on a large dataset or is it related to the
problems with the porting of GRASS to the RISC 6000 platform?
2) I have been trying to ratio two SPOT images using "r.mapcalc"
as follows r.mapcalc ratio=band3/band1 but the output image only
has minimum value=0, maximum value=1. I have checked the band
statistics for both bands and although I wouldn't expect the maxmimum
theoretical range of 256*256 values I certaintly expected a greater
range of values than 1 or 0. Is there something I need to do (like set
number of decimal places or reference a ratio lookup table) to carry out
image ratioing?
3) I was recently using "i.target,i.points and i.rectify" to reference a
previously (State Plane) rectified SPOT image in ROW, COL format to
State Plane coordinates. I would like to know if the i.rectify algorithm
uses a third order polynomial to rectify the input images or whether
it matches the most appropriate transformation equation to the inputted
control point coordinates?
Thanks in advance,
Tony Gale
Research Specialist
City of Austin Electric, Tx.
