We had the same problem at our site, but have no idea what causes the
problem. It may reside outside Grass, for instance in the monitor driver
/ X-window communications.
Martijn van Leusen
I am having problems running i.points on an RS6000. After selection of
a point on th eimagery and corresponding point on target the program
croe dumps. I believe the problem is with reading and writing to the
points file. I have tried to locate it using print statements in the various
programs but cannot locate the exact place th eproblem occurs.Has anyone experienced a similar problem? If so do you have any possible
solutions?Thanks in advance.
John
