i.rectify
Hi, all
After I used i.rectify command, the program showed the massage " You
will receive mail when i.rectify is complete". I'd like to khow how long
the process has been done. What is the answer on the screen?.
Thanks a lot.
taravudh
How big is the image that you are rectifying?
If you dont receive any message from i.rectify, it may mean that
your mailer daemon may not be running. It that case you can
find out if i.rectify is running using the unix ps command
for example
ps -e |grep i.rectify
if you find that i.rectify is not running your output image must
have been generated.
Hope this helps
Raghavan
taravudh wrote:
Hi, all
Thanks a lot.
taravudh
