idealized elevation model / linux
in the manual of the Water Resource Assessment Tool (WRAT) is
described, how to start erosion- and runoff-modelling: "The actual
analysis may begin using the digital elevation model to produce an
idealized elevation model." I am using GRASS on Linux and don´t have
access to WRAT. So, please, can anyone tell me, how to build up a
idealized (depressionless?) elevation map manualy?
WRAT is under src.contrib/NMSU/WRAT , just compile it and run it; the
idealized elevation model is produced by wrat itself.
otherwise, you may use r.neighbors and then edit the wrat project file,
writing there tre name of your newly elevation map.
good luck!
Roger
| Frank Lederer phone: +49/069/4960545 |
| Sandweg 64 Lederer@em.uni-frankfurt.de |
| D-60316 Frankfurt/Main |
_____________________________________________________________
Swedforest International AB
Combining Local Competence in a Global Network
Internet Home Page http://www.swedforest.se
Visit Address Enhagsslingan 4, TAEBY
Postal Address Box 527, S-183 25 TAEBY, Sweden
Phone +46 8 6383200
Fax +46 8 7587430
