IDRISI ascii format import
Hi there,
I would like to obtain the tool to convert arc info .e00 format to Grass
formats. I would very much appreciate it, if you could point out some
tips on how to convert .e00 format to grass format.
Thanks in advance for your help.
Aqbal Rail
Dept of Hydraulics & Hydrology
Fac. of Civil Engineering
University of Technology Malaysia
Tel : 607-5576160 ext 3026
Email : aqbal@tech.fka.utm.my
I finally found a tool to convert e00 format ARC/INFO files to
something more usable (ECV2000 tool. Runs only on Win through :frowning:
Now, how do I get the info from the resulting IDRISI .dvc and .vec into
Grass? I read that IDRISI binary .img files can be used directly, but
what
about these ascii files?
There is a v.out.idrisi module that will produce exactly the same
format
(.dvc & .vec) in an idrisi directory of the current mapset. But there
is
no corresponding v.in.idrisi.
So there must be a simple solution, only I haven't found it. So I ask.
regards
MHu
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
To convert from .e000 to IDRISI you can use etv2000 (for Windows only).
The evt2000 tools are available from:
ftp://ftp.geo.sbg.ac.at/pub/gis/idrisi/freeware/etv2000/
I used evt2000 to convert from .e000 format to IDRISI, but now I'm stuck
with IDRISI .dvc and .vec files that I don't know how to get into Grass.
I hope for someone to advise on this.
I don't know about any tool that can convert directly from .e00 to Grass.
MHu
