Idrisi vector file conversion
Hi. I have some Idrisi vector files which I need to import to GRASS.
I am not familiar with the format of DLG or ARC/INFO (or GRASS) vector
files, or I would simply do the conversion.
Does anybody have some routines out there to convert Idrisi vector
files to either DLG or ARC/INFO or GRASS vector files (or maybe even
to import Idrisi vector files directly)? Or, alternatively, does
anybody have some documentation on the format of any of these other
vector file formats I mention? We are using 4.0.
Thanks in advance,
  jim
This is what I got from grassu-list:
1) There is an idrisi2grass conversion program called grassidr.exe
available from ftp-server midget.towson.edu, dir /gis/modules. It
takes uncompressed idrisi raster files.
2) Vector data should be exported in ARCinfo `ungenerate' format, put
in a directory called `arc' under your Grass mapset, then imported
using v.in.arc.
3) There are other methods for converting raster files, but you do
not need them right now, so Good luck!
\_\_\_--\_----\_------\_-------------------- P. Martijn van Leusen ---------
\_ \_ \_\_\_\_ \_ Dept of Pre- and Protohistoric Archaeology
  \_\_\_ \_ \_ \_ \_ University of Amsterdam, The Netherlands
   \_ \_ \_ \_\_ \_ martijn@scanner.frw.uva.nl
    \_------\_----\_--\_--\_\_\_\_--------------------------------------
