Image Mosaic granules pointing to Google Storage private bucket problem
Hi.
I have some COG images stored in a private bucket. When I create a mosaic with an index file (SHAPEFILE) pointing to these images, no images are displayed. I can create the ImageMosaic store without errors (there are no errors in the LOG file), but the result is that nothing is displayed and no error message appears.
I have previously created the GOOGLE_APPLICATION_CREDENTIALS environment variable pointing to my service account file.
The following works for me: If I create a GeoTIFF store and in the connection parameters I put the image URL (cog://https://…/Alerta_30TUN_2021_cog.tif), GeoServer displays it correctly, so it is reading the service account file correctly.
Could someone tell me how to make my mosaic able to read the Google credentials (service account file) and display the images as GeoTIFF store does?
Regards
the image mosaic is using exactly the same underlying COG libraries as the GeoTIFF store.
Thinking out loud… did you tell the mosaic that it’s dealing with COGs, by adding the following in the
indexer.properties, before creation, or updating it afterwards in the mosaic property file?
Cog=true
SuggestedSPI=it.geosolutions.imageioimpl.plugins.cog.CogImageReaderSpi
See also: https://docs.geoserver.org/main/en/user/community/cog/update.html#imagemosaic-configuration-update
Hi, Andrea.
Yes, that information is added in both indexer.properties and .properties files.
The mosaic uses a mix of both public and private bucket images, but the only ones that are not visible are the ones from the private bucket. I think that if this were the problem, no images would be visible, neither public nor private.
On the other hand, as I mentioned in the initial message, the strange thing is that if I create a layer with a single image that uses a GeoTIFF type store, GeoServer displays it correctly. In this case, there is a checkbox to check if the image is a COG, and once checked, I choose the GS option in the Range Reader settings dropdown, but these options are not available when creating the mosaic store.
Thanks a lot.
the TIFF reader knows it might be COG, but the image mosaic can delegate to
a mix of different image
types in the same mosaic, so it can’t offer that option at the GUI level.
Maybe try adding the following in the indexer and mosaic property file:
CogRangeReader=it.geosolutions.imageioimpl.plugins.cog.GSRangeReader
Andrea Aime
Visit GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail
On Wed, Oct 2, 2024 at 10:20 AM Andrea Aime <
andrea.aime@geosolutionsgroup.com> wrote:
GeoTIFF store.
Cog=true
See also:
COG ImageMosaic from local storage to S3 — GeoServer 2.27.x User Manual
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
x.com
On Tue, Oct 1, 2024 at 1:00 PM Pedro Briones via OSGeo Discourse <
noreply@discourse.osgeo.org> wrote:
pbg https://discourse.osgeo.org/u/pbg
October 1
Hi.
correctly.
does?
Regards
Visit Topic
https://discourse.osgeo.org/t/image-mosaic-granules-pointing-to-google-storage-private-bucket-problem/85584/1
or reply to this email to respond.
To unsubscribe from these emails, click here
https://discourse.osgeo.org/email/unsubscribe/df849586d41deae84b39adef3c1c339e94476dd98602977ba6a1d17e2af692cf
It works!!! :grinning:
You have solved a problem that I have been trying to fix for a long time!!!
Thanks a lot, Andrea.
Regards
