I am trying to develop a strategy for examining cloud top radiances and
temperatures in GRASS4.0. I would like to be able to generate a hard copy
of the histogram of the count values (similar to that from d.histogram),
so that I could select different threshold levels. So far I have only been
able to eyeball the values from d.profile and d.histogram, but would
appreciate if you could suggest a more quantitative module by which to be
able to categorize the data.
Looking forward to your reply.
Lesley-Ann Dupigny.
Lesley-Ann Dupigny (dupigny@felix.geog.mcgill.ca) writes on 16 Nov 93:
The following example produces postscript output. This could be easily
modified for TeX, FrameMaker, groff, or whatever.
% r.stats -qc i=temperatures o=temp.histo
% g.gnuplot
gnuplot> set term postscript
gnuplot> set out 'temp.ps'
gnuplot> plot 'temp.histo' with impulses
gnuplot> quit
(then print temp.ps)
g.gnuplot is not part of 4.0 but will be in 4.2. It is currently
available via anonymous ftp from moon.cecer.army.mil in
grass/incoming/g.gnuplot3.5.tar.Z. Included in this is a manual.
I'm assuming that the -qc flags exist in the 4.0 r.stats...
--Darrell
Don't overlook the i.class function for quick looks at the data. I
provides a small scale image window, a zoomed image window, and a
window to hold the histograms. It outputs the means to a file with
annotation! It is meant to perform maximum likliehood classification,
so you must enter in two images. I use g.copy to create a copy of the
first image with a different second name, then i.group them together
for i.class.
Another way to get histograms is to use r.stats -a input=fname |
xgraph -bar. This tabulates each unique value, and the number of
counts for each value.
Good Luck!
dave
