Image registration
You should be able to use dd, with the skip= option to skip the first block,
setting your block size to the # of bytes to skip.
For example, if I have 87 bytes of header stuff I want to skip, I
would use:
dd if=datafile of=data.raw ibs=87 skip=1
Then just use the raw data file in GRASS.
- Bill
