You must excuse this message if you find it to peripheral for the GRASS mailing list.
My problem is that I have a text file, where each value for the raster consist of 5 characters.
I can't get this into GRASS. I have tried to read all available documentation on the useful Gawk tool, but I can't find that it enable me to add space delimiters between columns, because also this tool requieres some kind of delimiters. I have a Fortran 90 program that should do the job but no F90 compiler.
Any suggestions ?
Best regards Trond Rafoss
tlf 64949473
mailto:trond.rafoss@planteforsk.no
http://pf-tra.nlh.no
s.mail:
Fellesbygget
1432 Aas
NORWAY
Any suggestions ?
If you are running Unix (or Linux, or aix, or...), try sed :
sed 's/...../& /g' < your_file > another_name
this will introduce a space each five characters.
You may also use Excel (import fixed length text file) with WinXX
Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
