importing ARC/INFO export format and STDS format
> Hello,
> I am trying to bring in a point coverage database into GRASS. The database
> comes in two formats: ARC/INFO export format and STDS format. I don't have
> access to ARC/INFO. Are there free utilities to ungenerate this database?
> Or, does anyone know what the STDS format is? Or better yet, how do I
> import STDS format into GRASS?
> Thanks for your help!
> Henry Shin
Don't know about the STDS format, but you can forget about the export format,
as there are no conversion tools available. I suggest you try to find
someone who has Arc/Info to convert it to ungenerated format (if you can't
find someone, send me an email and I'll I see if I can help you out).
Philip Verhagen
You should be able to find the SDTS format on the Federal Geographic
Data Committee home page on the WWW (http://www.fgdc.gov)
The GRASS sites file format is pretty simple, the other file should be
editable to the required format.
