importing ARC/INFO export format and STDS format
Phillip,
Thanks for the offer! I have not found anyone with Arc/Info yet. But, I am
going to try to import STDS formatted files first. If I can't work that
out. I might call upon your help. Thanks again.
Henry Shin
Don't know about the STDS format, but you can forget about the export format,
as there are no conversion tools available. I suggest you try to find
someone who has Arc/Info to convert it to ungenerated format (if you can't
find someone, send me an email and I'll I see if I can help you out).
Philip Verhagen
                    philip@raap2.ivambv.uva.nl
                             R A A P
                       Plantage Muidergracht 14
                         1018 TV Amsterdam
                          The Netherlands
                       tel: +31 (20) 421 62 00
                       fax: +31 (20) 421 42 90
               http://raap2.ivambv.uva.nl/home_eng.html
