importing ARC/INFO files
I have a file that is supposed to be an arc/info file. I'd like to
import it into GRASS. I have tried using v.in.arc but on each attempt
I have received the message: ERROR: Reading LINES file
Below is the firs 20 lines of the file that I am trying to import.
Can someone tell me what is causing the error?
Thanks.
-Jim
EXP 0 /DATA3/KOFFMAN/PENDERGAST/SITEMAPS/FH_MAPU.E00
ARC 2
         1 1 0 0 0 0 2
4.4081297E+05 3.6828878E+06 4.4076409E+05 3.6828938E+06
         2 2 0 0 0 0 2
4.4081328E+05 3.6828893E+06 4.4076581E+05 3.6828950E+06
         3 3 0 0 0 0 2
4.4101038E+05 3.6827960E+06 4.4096928E+05 3.6828353E+06
         4 4 0 0 0 0 2
4.4092441E+05 3.6829453E+06 4.4093116E+05 3.6830153E+06
         5 5 0 0 0 0 410
4.4096928E+05 3.6828353E+06 4.4096906E+05 3.6828355E+06
4.4096884E+05 3.6828358E+06 4.4096863E+05 3.6828360E+06
4.4096844E+05 3.6828363E+06 4.4096822E+05 3.6828363E+06
4.4096800E+05 3.6828365E+06 4.4096778E+05 3.6828368E+06
4.4096756E+05 3.6828370E+06 4.4096734E+05 3.6828373E+06
4.4096713E+05 3.6828375E+06 4.4096691E+05 3.6828378E+06
4.4096672E+05 3.6828378E+06 4.4096650E+05 3.6828380E+06
4.4096628E+05 3.6828383E+06 4.4096606E+05 3.6828385E+06
4.4096588E+05 3.6828388E+06 4.4096566E+05 3.6828390E+06
4.4096544E+05 3.6828390E+06 4.4096522E+05 3.6828393E+06
On Fri, 19 Apr 1996, James Curry wrote:
Thanks.
-Jim
ARC 2
         1 1 0 0 0 0 2
         2 2 0 0 0 0 2
         3 3 0 0 0 0 2
         4 4 0 0 0 0 2
         5 5 0 0 0 0 410
The appropriate import command to use would depend partly on what type of
data (polygon, line, or site). You don't specify what the output command
was used to export this data from arc/info but that command would then
determine the appropriate grass command to use. I don't think this is a
data format that the v.in.arc command was intended to use (either polygon
or line).
Try asking your data source what they used to create this file and if it
is something importable by grass. Typicall arc/info data export commands
would be "export" for other arc/info systems, "ungenerate" for v.in.arc
in grass, "arcdlg" for dlg format data, or "arcdxf" for cad format data.
It would be a good idea to request data export files in a format you know
you can read into grass such as dlg or "ungenerate" format for v.in.arc.
So... Check back with your source and figure it from there.
-Dave Viebrock
viebrock@gis.cwu.edu
David is correct in his assumption that this file is not in the correct
format; the .E00 extension identifies it as an Arc/Info "export" file, a
proprietary format used to share coverages between users. What is needed
is the "ungenerate" format. See the v.in.arc and v.out.arc pages for more
details.
        -Malcolm
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
> Hi,
> Thanks.
> -Jim
> ARC 2
> 1 1 0 0 0 0 2
> 2 2 0 0 0 0 2
> 3 3 0 0 0 0 2
> 4 4 0 0 0 0 2
> 5 5 0 0 0 0 410
or line).
-Dave Viebrock
