Importing ARC/INFO
Hello users:
Tarek Sadek give us a great tip for the v.in.arc text attribute file, however
we are importing very complex ARC/Info land use coverages and we still have
troubles with the islands. ARC/Info tag each island with an -99999 ID, so when
the file is imported those features are not right labeled.
Any ideas?
Thanks a lot again!
Does ARC really use -9999 for a user-ID, or is this the record number? I
would be very much surprised if every island had a -9999 user-ID, as
the user-ID is what you want your label to be, while the record number is
for internal management of the data; it's obviously quite easy to open the
ungenerated label file and edit the -9999's out. GRASS should be able to
build the topology without.
Philip Verhagen
      S t i c h t i n g R A A P
    Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
          1018 TV Amsterdam
           THE NETHERLANDS
phone: (31) 20 525 5835
fax: (31) 20 525 5834
e-mail: motte@xs4all.nl
